So, my mums laptop(inspiron 1545) was dropped and the hard drive failed. I replaced the drive and installed a different version of windows vista to what it came with(no recovery CD and the recovery partition was on the dead HDD). However, the install was useless - random and repeated crashes, hangs etc. It would also not install any windows updates, got to configering updates stage 3 of 3 - 100% then hangs.
I then formatted the drive and then re-installed windows, however, the issues are still there...and i'm at a loss as to what else to try? Anyone got any ideas?
RAM problem?
thanks
RAM problem?
thanks
Run memtest for about an hour to be certain theres no problems.
