Dell ST2210 - Help please?
29 Apr 2010
North Wales
Hi everyone, My Dell ST2210 Is not fitting to the full screen. It's got a black bar around it.
I've installed the drivers from the AMD website, the drivers for the monitor.
Resolution is 1920x1080
Connected via HDMI - DVI Cable
I've tried adjusting the settings on the monitor itself, but the "Horizontal Position" and "Vertical Position" options are grayed out and I can't select them.
Thanks in advance!
Are you using Catalyst 10.1 or above? Try having a play with the 'overscan' in the CCC and make sure it's not set to an odd value. Do you have the cable connected to the graphics card's DVI and monitors HDMI?
thanks PCM2 that was that sorted it - friend filled me in about that seconds before you reply. Thanks anyway pal.
