Dell Studio XPS quick display question - helllp
  • Thread starter Thread starter Sam
  • Start date Start date
Sam
Sam
12 Jan 2003
Surrey
Hi Guys
Got the above laptop but find the display is soooo bright. when i disconnct the power the display seems to dimm to a far nicer brightness but i cant for the life of me find where i can change these settings ?
cheers
Sam
You got a 'fn' key on your keyboard? Usually a combination of that and another button will sort you out, on my Latitude its the up and down arrows.
You can also go into the power options and change the defaults for both plugged in and unplugged. :)
