I received the tech support email today about the issue ( which I have not encountered ) but I am confused about several points the support email makes.
It basically says not to run the monitor at a refresh rate of 30Hz, because it is optimally set up for high refresh rates. It then tells you how to select a higher refresh rate in Windows.
Thing is, that there isn't even a 30Hz option in my settings so why in heck do I need telling not to run it at 30Hz?
Under some circumstances is there a 30Hz refresh rate? Perhaps on HDMI or HDR or something?? What am I missing??
