I've bought a Dell U2312HM (not from OC) and the power button seems to not work roughly 1 in 4 times you press it. Has anyone else experienced this? Looking like a return to me.
I initially thought it was how hard or certain areas of the button you pressed but it seems not. If you power yours on and off in quick succession does it respond to each request correctly?
Suspect the kettle lead has an issue as it makes a static noise when wiggled around. Same on a different monitor. I think the power button also has issues though as if it was purely the kettle lead I'd have thought the image would flicker.
