Bought two of these for 3D modelling/ Photoshop work (Wide gamut not required) and frankly Im a bit disappointed in them.
Think maybe I've just been unlucky and have panels with issues but wanted to check here
Issues:
1) One of the monitors is a fair but duller at the same settings as the other panel.
I have to crank the brightness/contrast up a lot to get the same perceived brightness and sharpness from both screens.
2) Yellow/brown "shadowing" at edges of each monitor, particulalrly noticable against a white background.
Cant see past it makes screen unusable tbh. Reminds me of an old AOC model crt monitor I had...white screen with brown/grey tint at the corners/edges.
The screens look "dirty" at the edges and corners
NOT what I expected QC wise form Dell and not with this monitor.
3) One monitor is visibly not as sharp as the other. Text is not as crisp and colours are not as vivid.
Both panels are revision AO2 dated October 2001.
*EDIT*
I played with calibration settings and it improved the brightness issues a fair bit, but the "dirty white screen" problems still exist.
So a bit deflated after looking forward to them so much, reading all the reviews etc.
Seller ok with returning them so can get a refund within7-14 days, so not a disaster.
Some questions?
* Are the problems I had symptoms of a bad panel?
* Are these common issues with Dells (bad QC?) and is it a lottery to see if you get a good panel?
* Any alternative 16:10 24" monitors to the Dell at the same pricepoint worth trying?
Thanks for any help.
Issues:
*EDIT*
Some questions?
