Dell U2711 Problem...
4 Sep 2005
UK
Was away for a week's holiday, just got back today, during this time the screen was turned off and no power to it, got back today and turned comp and monitor on, everything works fine, except that the Exit (from Menu) led, the one above the on/off switch (in normal use) comes on every so often (every 20-40 seconds), stays on for a couple of seconds and then goes off, it gets quite annoying after a while.
Anybody any ideas the reason for this and if so the cure?
Have powered the monitor off, removed power cord for a short time then reconnected it, but no change.
Apart from this the monitor works fine.
Thanks...
