*** Dell Ultrasharp 2408WFP 24" Widescreen LCD Monitor @ £399.99 inc VAT ***
Suspended
18 Oct 2002
OcUK HQ
*** *** Dell Ultrasharp 2408WFP 24" Widescreen LCD Monitor @ £399.99 inc VAT *** ***
The Dell Ultrasharp delivers rich, life-like imagery and accurate color representation to the home and office with TrueColor Technology (110% color gamut)1 and 3000:1 dynamic contrast ratio. Together with a fast response time of 6ms (typical) that helps prevent ghosting and smearing, viewers can enjoy a more satisfying viewing experience when engaging in digital content creation, gaming and HD entertainment. The 2408WFP brings superb image quality to your desktop with stunning resolutions of up to 1920x1200. Offering about 30% increase in content area over a 20 inch display, the 2408WFP gives you more resolution to work in, increasing efficiency and productivity for professional content creation like game development, photo/video editing, multimedia and design. Extensive connectivity options including VGA, DVI-D with HDCP, S-Video, Component, Composite and HDMI allow you to hook up to most PCs and electronic devices. Dell UltraSharp 2408WFP is one of the first flat panel monitors to offer DisplayPort connectivity, industry-endorsed technology that helps reduce complexity and enhance digital quality. Enjoy the Ultrasharp advantage with intuitive built-in features like a height adjustable stand, 4 USB 2.0 ports and a conveniently located 9-in-2 media card reader - small thoughtful details that make life that much easier.
- 1920 x 1200 (WUXGA+) Optimum Resolution
- Supports advanced features like PIP (Picture-in-Picture) and PBP (Picture-By-Picture)
- 16.7 Million Colours
- True Colour Technology (110% Colour Gamut)
- 3000:1 Contrast Ratio
- 6ms Response Time
- 400 cd/m2 Brightness
- Anti-glare surface
- Two DVI-D Input w/HDCP Support
- One Analogue Input
- One S-Video Input
- One Composite Input
- One Component Input
- One HDMI Input
- One DisplayPort Input
- Height adjustable stand (100mm travel)
- VESA mounting compatible / Security slot : Yes (100mm) / Yes
- Integrated powered USB 2.0 hub : 4 downstream / 1 upstream ports
- Integrated powered 9-in-2 Card Reader
- Warranty : 3 year next business day exchange supplied by Manufacturer. (Call Dell on 0870 9080800 and have the work number from the original packaging handy, request to speak to the Dell Warranty Monitor Line)
Just £399.99 Inc. VAT
BUY NOW
What are the important features to buy a 22 inch wide screen LCD monitor? I want to buy a 22 inch wide screen LCD monitor for viewing movies. My budget is $ 350. I want high quality picture. So what monitor do I buy?
Erm, you are very much in the wrong thread, but as you asked, you must only get the 2209WA from dell. Do not buy any other screen, they are all inferior in the 22" market.
Usual ISO standard for us like most others.
That is?
Also
What about people from Ireland, If we are to buy one and it goes bang. Would it be Dell Uk or Dell Ireland(even tho they are the same)
And lastly, Do you do finance.
if i wanted to buy 3 of them :D
Dell will change it direct if you have a dead pixel, they look after everything, not ocuk. When mine broke they delivered a new one the next day and took my old one at the door
