Dell Wyse 3040 Thin client Linux
7 Jan 2009
Hey.
Recently acquired a Dell Wyse 3040 thin client.]
I know they're not particularly powerful, Nor intended to be a full blown system. However it does have a 16GB SSD installed and from what I've seen online you can install Linux on it and run it as a standalone just fine.
The issue is...I've not successfully been able to do this?
I've tried Lubuntu,Linux Mint & Xubuntu and all fail to install at some point during the instillation saying it was unable to install but doesn't give me any detailed or technical explanation to why.
Does anyone have any experience with these thin clients?
Specs -
Intel Atom X5 Quad Core
2GB Ram
16GB SSD
2.4 & 5ghz Wifi.
I use a HP Thin client for work and from what I understand, they are locked down so pretty much useless to you or me.
Essentially a dumb terminal. That’s not to say there is a means of flashing the firmware to make them useable for other things. That I do not know.
To help in diagnosing the issue you could try using verbose settings in your linux install. You might be able to spot where it crashes. Usually it’s a driver or some data that can’t be written etc.
Appreciate the replies folks!
See i had a look to see if there was any particular firmware or bios for it to "Unlock" so to speak but cant see any, From what I've read people were having issues and they just pressed F2,Reset bios settings and they were able to install Linux...but this doesn't seem to work on my end.
I mean it could be down to the Linux versions im using...i might give React OS a go and see if that installs.
good call thanks, Its a shame that i cant install an MSATA drive into the system to rule out a potential issue with the onboard soldered 16GB storage chip..
It does boot into a linux live distro just fine.
I used to use a 5070 Wyse as a firewall and it was exceedingly fussy about USB installation media types.
Either the ports undervolt, or there's something else that causes instability. If you can set up a PXE boot environment that would isolate that issue, I think that's what I ended up doing in the end.
Hey.
Specs -
2GB Ram
16GB SSD
2.4 & 5ghz Wifi.
I have a 3030 and bought 2 years ago so i could play around with installs,reading your post you can kind of run them as a full system as i did manage to install full Linux Mint Cinnamon from 2023 and im sure it has windows 11 pro 23H2 at the moment so it can be done.
They are a real pain in the bum to get a Os on and real stress testing experience but it can be done and i did change the 16gb ssd to 32gb
I found Belina Etcher to be the best in order to get the Os onto these machines,and a 16gb flash drive is a must.
From what i have seen the 3040 16gb version is the choice for this task as the 8gb version there is a difference other than the storage.
The problem is its a 5v system as most thin clients are either 12v or 19.5v so its a big ask from a 5v system, i have thought about buying one to do what your wanting to do but from my experience with the 3030 there is much better options out there for not a lot of money and i did buy a dell 3060 8th gen Micro pc with a 8500T cpu which has turned out to be the best small pc i ever bought and it runs windows 11 24H3 with ease but does have 16gb of DDR3 1600 and a 512Gb M.2 storage, Its a good daily driver pc but power wise it draws 45-55 watts full load,10-18 watts browsing with multiple tabs open and sleep mode its between 2-3 watts
Quick update on the Wyse 3040. I bought the 16GB variant very cheap off *no competitor talk*
Installing Alpine Linux on it is like falling off a log and it runs great. Highly recommend it for those trying to squeeze all they can out of these little boxes!
I started with Rufus on Wind blows to burn the Alpine iso to an SD card. Booted from that with LAN cable connected then ran the Alpine installer.
The internal disc is ID'd as mmcblk0 so choose that as your target. Rest is plain sailing. The extra notes on Parky Towers might be of interest also.
I've used these a few times to set up retro gaming systems, they are great for installing DOS on because their sound card is Adlib/SoundBlaster compatible so you can party like it's the late 80s/early 90s.
I realise this doesn't help but I thought it was a cool thing to mention :P
