Hello all,
I am after a Thunderbolt (USB C) dock for my friends XPS 13 9360 that can do the following.
Two screens
Power over USB C
USB Type A's for Keyboard and Mouse.
Ethernet (nice to have)
I use a "Dell Part 452-BCDJ" (Business dock WD15) at work. It probably makes the bare minimums of all of the required. The dual screen is a bit "meh" as it is a HDMI and VGA but there is a higher end version (WD19) which will has better outputs.
I've got a WD15 at work too, it's got mini displayport so you can use two digital connections.
It's restricted to 1080p with two monitors connected.
So do you use a splitter cable coming from the display port?
