Dell XPS Baton - 2 Rolled Up Screens!
I'm guessing they've got a very small cut down set of components in the centre tube thing. It's the only way it could work really.
Love the concept.
Can't see it being impossible either.
Although, it would probably have to be crippled because of the heat dissipation, etc.
Oh, and the fact it would cost more than the Moon.
Looks like a mental idea, i give it 5 years. Something similar will be out. Until then i will stick to the Sony Viao TT.
About time too - they've been harping on about the advantages of flexible oLED screens for ages - it will be very interesting to see how this develops- don't dismiss the power of this little beasty either - depending on the size of the baton you can squeeze a lot of power into a small space now - or it will simply rely on the power of your desktop back home and stream the apps directly from it as they did when they ran crysis on the eeeeeePC
