Dell XPS Trackpad help
29 Jul 2004
Esher
Hi everybody,
On my old XPS on the right hand side of the pad and the top you could drag your finger and then the page would scroll down.
On my new one, sometimes it happens and sometimes it doesn't.
What is the trick to get it to work?
Thanks everybody
try two fingers swiping down vertically? check synapsis properties and device settings for list of gestures, you should also be able to use 3 fingers swipe to go back and forward pages, and two fingers to zoom in and out
You were right, its the 2 fingers swipe.
I was doing it with my 2 fingers next to each other, I only found out that you need like a cm gap between your fingers for it to work
Cheers though :)
You can usualy get one finger working as well, there are a lot of options for trackpads on Dell systems.
