Had a chap come round today to remove some dinks that appeared on the cars return from the dealer
Never had a smart repair before, but the chap came well recommended so I thought it was worth a shot.
There was a tiny dint in the bonnet with a larger one in the offside front wing. Chap turned up and got to work, accessing the dints from under the wing's splash guard and under the bonnet padding.
All done in around an hour. The bonnet dint is gone, and the larger wing dent is almost 100% - if you catch the light in the right way, you can just make out a minor oddity in the paint as the reflection is slightly different to the surrounding areas. A corrective detail should help.
£100 + vat. So cheaper than the £75 + vat per panel shown online.
All in all chuffed and wouldn't hesitate to recommend this chap locally (Aberdeen and it's shires).
I should have taken some pics, but I couldn't bare to look at the car - I also didn't expect him to get them out.
So there you go, learn something new every day.
