Hi all,
I posted on here a little while ago with an AD query and never got to the bottom of it, so i thought i'd start another thread to try and get things sorted.
Basically, I am trying to add http://intranet.domainname.com to the local intranet sites list within Internet Explorer to all users within a specific OU in our Active Directory domain.
I can manually add this setting by performing the following:
Open IE > Tools > Internal Options > Security Tab > select Local Intranet icon > Sites > Advanced > and then adding the URL in here.
However, when i try to deploy this setting via GP it does not seem to replicate.
I have found the setting within GP under User configuration > Windows settings > Internet Explorer maintenance > Security > Security Zones and Content Ratings > and then clicking Modify settings under the Secuirty Zones frame.
But the URL's i add here do not get replicated to the users nor the to the other domain controllers on the network?!
Can anyone advise where i am going wrong?
Thanks
Dan.
Thanks
Dan.
