Oright folks.
Looking for advice on new build - budget just under the £1k mark. I do allot of After Effects and web based design work and require a good amount of RAM. After a 64bit machine that will last a few years. Not bothered about overclocking just a machine that will take anything i throw at it and can handle multiple design apps running, good for rendering 3D, good graphics card, will run without any problems
etc etc.
Any advice would be great.
I posted this a while ago Creative spec but not sure if any of this is out of date. I now really need to get a machine sorted.
cheers
etc etc. Any advice would be great.
cheers
