Not really sure where to put this tbh so I'll try my luck in here.
The following pic is taken from below my desk
This is driving me crazy now I want some sort of cable management.
My initial idea was to build an MDF/plywood box to encase all the cables, I bought the materials but my workmanship isnt up to much so i gave up on that pretty quickly.
What options do i have ?
I will more than likely run trunking down the wall anyway for the stuff that is plugged into the lower sockets.
Thanks for looking
James
Thanks for looking
James
