Desk mount arm
16 Aug 2011
Ireland
Quick question hoping someone can give help/recommendation, I recently bought one of the LG monitors when they went on sale, I aim to use it as my main and relegate my previous monitor to secondary duties as my previous one died, I have been using a "ET01-C011 Swivel Arm Desk Mount" on it and planned to do the same, however it doesnt seem compatible with my Asus PB278Q monitor, when I detach its base stand it leaves a square recess which my current desk arm is ever so slightly too big to fit in, it is a vesa 100x100 arm, and the holes look to match up, it just wont fit into the recess of the monitor, does anyone know of any desk arms that would fit for certain? I dont want to buy a new desk mount and face the same problem
Thanks in advance.
Hi
You can buy an adaptor plate which fits into the square recess thus making it flush then you can just connect your current monitor arm to that.
Google search -Newstar fpma-vesa100 vesa conversion plate.;)
Hi
Perfect! Thanks very much
