Desk top for AutoCAD
8 Jul 2011
Hey All,
I am starting a new job soon and the role requires using CAD in both 2 & 3d.
The new employer has asked me to spec a PC that will handle CAD well and I thought I would start here.
He has not set a budget but in his words "all singing and all dancing" should be had!
So could you recommend me a PC spec, pre built for around £1k or what you feel will do the job well.
Kind regards
Caddy
Have a look at some of the i5 and i7 pre-built bundles in the OcUK store.
Most of them should fit the bill with ease.
Depending on whether you are working in 2d or 3d you might need to get a bit more detailed:
Consider an Nvidia QuadroFX card rather than a gaming card.
Consider 8GB to 16GB of RAM.
Turn off vertical sync in the OpenGL settings on your graphics card driver.
Make sure OpenGL is set on the Display options in AutoCAD itself.
out of all the bundles available i cant find anything that would be perfect for you :(
ideally you would want something like this:
YOUR BASKET
1 x Intel Core i7-2600K 3.40GHz (Sandybridge) Socket LGA1155 Processor £239.99
1 x Crucial RealSSD M4 128GB 2.5" SATA 6Gb/s Solid State Hard Drive £183.98
1 x OcUK GeForce GTX 460 OC 1024MB GDDR5 PCI-Express Graphics Card £109.99
1 x Asrock Z68 PRO3 Intel Z68 (Socket 1155) DDR3 Motherboard £105.98
1 x Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) £59.99
1 x XFX Pro 550W Core Edition '80 Plus Bronze' Power Supply £54.98
1 x Thermalright Silver Arrow CPU Cooler (Socket LGA1366/LGA1155/LGA1156/LGA775/AM2/AM3) £50.99
1 x Antec 100 One Hundred Ultimate Gaming Case - Black £43.99
1 x Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) £40.99
1 x Sony Optiarc AD-7260S 24x DVD±RW SATA Lightscribe ReWriter (Black) - OEM £16.98
Total : £922.87 (includes shipping : £12.50).
however, the best i can find is this:
YOUR BASKET
1 x "Titan Spinosaur" Intel Core i5 2500K 3.30GHz @ 4.60GHz DDR3 Sandybridge System £600.80
1 x Overclock selected £20.00
1 x No Operating System £0.00
1 x OCZ Agility 3 120GB 2.5" SATA-3 Solid State Hard Drive (AGT3-25SAT3-120G) £169.99
Total : £979.38 (includes shipping : £15.50).
i would ask in the customer service section if you could get one of those, but to change the i7 2600k and the motherboard to the Asrock Z68 PRO3
this will very likely take the price up to ~£1100 though :(
