Need a bit of advice please.
I have a desktop that is hooked up to dual monitors. I have a laptop that I want to use on one of the monitors which I can switch to when needed.
So normally - desktop using both monitors.
Sometimes - desktop using one monitor and laptop using the other.
Can this be done by somehow hooking the laptop to one of the monitors using a DP cable (or other) and switching the laptop to the monitor when needed - without having to buy a KVM or anything of that nature?
If not is there a really simple switch type device that would do the trick without having to spend a fortune on it?
Many thanks
Many thanks
