MikeOCUK said:
does it say 0.0.0.0 for IP address, or 169.xx.xx.xx?
few things to try
- test it with your cable
- run the command prompt again type 'ping 127.0.0.1' does it give a result (this tests the TCP/IP protocol stack.
- try setting the IP address manually, set it toa similar IP address as yours, so if yours is 192.168.0.2, set that to 192.168.0.10 (only change the last section) make sure the subnet is the same as yours, and set the defualt gateway, and the dns server address to the IP address of your router (most probably 192.168.0.1)
Tested it with the cable at first and still nothing
In the cmd prompt i put 'ping 127.0.0.1 and got the following
Ping 127.0.0.1 with 32 bytes of data
Reply from 127.0.0.1 : bytes =32 time < 1ms TTL = 128
Ping statisticd for 127.0.0.1
Packets sent 4 , Received =4 , Lost = 0 (0% lost)
Aprrox round trip times in mili seconds
Min 0ms Max 0ms average 0ms
I Changed the subnet , ip ect but made no difference
I noticed i have to area connections
-Local Area Connections
Network cable unplugged
Marvell Yokon 88E8001/8003/8010 PCE gigabit Ethernet
-1394 connection
Is it picking up the wireless card ?
Thanks for your time so far
Regards Skywalker
