Desktop can't connect
31 May 2013
So I recently bought A new AMD desktop PC, and just finished setting it up.
However for some reason, when I connect to my wireless network, after I put in the security code the connection fails and for the life of me I can't figure out why. Any help would be gladly appreciated, thanks.
First off check that you have got your Wi-Fi password correct (incuding capitalised and non capitalised letters, no accidental spaces etc) Try resetting your wireless adapter, turning off your router/modem at the wall, waiting 30 seconds, and then turning them back on again. Also try a system re-start. If none of those work, try un-installing and re-installing network drivers.
If you have Virgin Media, blame them automatically without trying any of the above and rage at them endlessly over the phone. Because even if they are not to blame, they deserve it. :D
