When you minimise it you will also notice an icon in the system tray, right click and select minimise to tray and hey presto it will disappear from the taskbar. When you get a new email it will pop up and scroll across in a little window. (That is the only cool feature in Outlook)MagSafe said:Is there a way of doing this with Outlook 2003? I'm using it in work and its kind of annoying having to keep it open in my taskbar all the time.
AJUK said:What client are you using? Thunderbird has an extension that minimises to the system tray and if you set it up to check for new emails regularly it will pop up with a notification. Eudora and Outlook 2003 do the same.
