Hey guys, Just a quick problem. I added more ram to my computer which reset my overclocks I had set.
So I went and put my I5 3570K to 4.5ghz, It has watercooling and I have the voltage upto 1.36, It normally sits around 1.34 max under load. Temp stays around 50c as well.
Anyway, The ram should be able to take 1866mhz, But when I set it to that and start windows up, shortly after everything locks up and freezes. I've had to set my ram to use 1600mhz to get it to run but am unsure if its the CPU or the ram causing it. Cause I've had a lock up later on using my PC for no reason :S
