Desktop icons - moving them closer together?
Consigliere
12 Jun 2004
SW17
I want to move my icons around a bit but i have noticed it is quite limited as to how precise i can be, if that makes sense?
I can't move them around too much and instead they only 'slot' into specific places.
Can this be solved?
I'm sure there's a setting somewhere that sets the distance between the icons, as I believe I've seen it in the past.
Can't remember right at the moment, what version of windows you using?
