Desktop Mouse Cursor Gets Stuck in Pcvr
26 Nov 2010
Thorne Yorkshire
Hi folks,
This may just be an Ams2 issue. Not sure. I'll have to do a few more tests on other games..
In pcvr sometimes my mouse pointer gets stuck in top left corner of my monitor desktop. I can attempt to move the pointer with my mouse and it sort of judders instead of moving then snaps back to the corner.
I noticed this when playing Ams2 last night. Earlier on in the day mouse was fine with Microsoft flight simulator.
Google search suggests quite a few folk struggling with a similar issue in pcvr generally.
This happened on a Reverb G2 and a Quest 3.
Any ideas please?
If my pro controllers are pointing toward the screen I get this issue, I usually put them back on the dock or point them away from screen.
Thank you. I'll try taking the batts out of the controllers or tuck them away somewhere out of sight when it next happens.
ive had VR for a few years now, and every time i go onto Virtual Desktop and take my headset off, i usually get a mouse pointer that i can not move, or its very limited in movement, like just the bottom of the screen only, i just put it down to because the desktop has changed resolution to match and in VR mode is incapable of using my mouse
