Desktop PC Build Advice
25 Oct 2009
Caerphilly
Looking to upgrade a relatives desktop PC internals.
Usage includes general browsing, a little photo editing, low intensity radio programs... i.e nothing heavy.
Whats the general go to board and cpu bundle these days? I built a decent FM2 desktop build around 10/11 years ago, which has done brilliantly but time to upgrade.
Have been looking at the R5 7600X for about £200 but not sure if thats overkill and to maybe go AM4 instead?
What do they have? If they do nothing intensive, a spring clean, an SSD and some ram may see them through. The biggest concern would be windows 11 compatibility when 10 support ends at the end of next year. Unless buying used I would leave off am4.
Off the top of my head I'm not sure! will find out.
W11 is part of the reason for upgrading, current board/cpu doesn't support W11 upgrade. So to future proof would like to upgrade now.
Will stay away from AM4 then thank you, any reason though? CPU's are quite cheaper... I'm not up to speed with current tech and roadmap on future gens/releases.
Any CPU from Ryzen 2000 and 8th gen intel will support windows 11
My question would be if there's any need to buy the computer new. If they're happy with the performance of FM2+, which is a pig of a CPU even back in the day then any semi-recent CPU in the last 5 years would be sufficient.
The am5 is a bit more expensive but the worst am5 CPU is better than the best am4 one. Unless you need some performance, as Tetras said, the ex office machine may be the best budget option.
I thought you just needed uefi?
My base CPUs to buy for a lower-end build are a Ryzen 5600 or 12400, but AM4 has no integrated graphics unless you buy a G model and Intel only has integrated graphics if you do not buy a KF/F model.
Ryzen 7600(+) would likely be big overkill for the usage you described, but since it is the newer platform the future upgradability (e.g. CPU, RAM, M.2) will be better. AM5 CPUs except the F have integrated graphics.
Cooler is optional on the following build, because the CPU has one in the box. Ryzen 7600 does too, but 7600X does not.
My basket at OcUK:
Total: £503.89 (includes delivery: £0.00)​
My basket at OcUK:
That's great thank you. Will look into the 5600's and 12400 CPUs this evening and post back with a possible build. Thank you again.
They've got kind of cheap those, FYI: the 8500G is a lot different to the 8600G. It has no NPU and uses 4x 4c cores (they're clocked lower), but it does have good power consumption. The 8600G is "full-fat", with no 4c cores.
Thank you.
This is what I've been looking at:
RAM checked for compatibility with Mobo.
Thank you.
Looks fine. If it was me, I'd get stock memory (like: Kingston KVR52U42BS8-16 ) 'cos I wouldn't want to be troubleshooting XMP for a relative in 2 months time, but your pick would give you the best performance.
Thank you - will look at that stock RAM. What would be the issue with XMP in a few months time?
