- 10 Jun 2005
Hi all,
wasnt sure what section to put it under, so i though this would be the best place.
Well, i re-installed XP on my desktop machine earlier this morning, and it went well (what i thought anyway). Ive formatted and done fresh installs loads of times, but never came across this before.
Now, my desktop reboots itself on its own, at random. Sometimes it will boot up, get to the BIOS screen, then reboot, then reboot, the time between reboots gets smaller and smaller, then reboots, eventually until its almost just resetting itself. Other times, it doesnt do it, it will boot up nicely, load windows, log in, and no problems.
Other times the machine may have been runing for an hour......and your not doing anything...then all of a sudden....REBOOT!!! It makes like a sort of slight 'clicking' noise.
It also boots sometimes......(you can year it) & everything SOUNDS normal....but there is no input to the monitor.
Its very,very strange, theres no particular pattern to it either.
I swear someone is looking at me taking the p*ss!!!
Any ideas what it may be? Any suggestions to what i could try doing?
Any help appreciated - MANY thanks
Jim
Jim
