Desktop Speakers help
12 Feb 2014
Hi there,
Looking for some small desktop speakers - what are the best you can get for £60 or under?
Edit - I already have some 180w bookshelf speakers in room, these will mainly be for watching videos/netflix/maybe some games. Also have to be black and look professional if possible!
Thanks!
Depends what the usage will be; but stereo will offer better sound quality, especially for music use. Cheaper 2.1 isn't worth bothering with when it comes to music, although they are perfectly fine for gaming.
Anyway; Creative T20 are probably the best choice for small stereo speakers. Edifier 1280T are better and worth the extra £30, but they are larger speakers. Depends how small you need them to be. If the T20 size is what you're after, then there's nothing else as good that's a similar size.
