desktop too zoomed in on lcd tv
Thats the one, spot on, thanks.
Knew i had used something like that in the past.
The TV supports 720p, 720i and one of the 1080's (cant remember which one) it does look good though do you think i should change it ?
I just thought higher the better.
No its fine keep it to what you like best. The reason i mentioned it was because you said it was a cheap LCD and generally cheap and 1080 don't go together, but if your happy with it thats all that matters
