Destiny Help?
6 Dec 2002
Stoke on Trent
Started playing Destiny 2 again but when I reinstalled it I was taken to the start maybe when the flying thing finds me and brings me back to life. My character is level 190 something and all the enemies are like 1000 plus and I can't kill nothing? Why has it broke?
Have you got 3 weapons equipped?
This can have a bearing on your attacks if you have a weapon slot empty as it lowers your stats.
I thought the main campaign had been vaulted, though and shouldn’t be accessible.
Have a look on the character selection screen. From memory there might be an arrow next to the character that will increase your light level to whatever the new minimum is now.
If that's not there then your old gear will have probably been sunset. When you load in, go to the menu and go to the collections tab. You should be able to pull out gear from there at the new minimum level.
Alternatively again, just create a new character as it sounds like you won't be losing much. Every expansion before Shadowkeep is gone.
I'm still playing a lot of Destiny if anyone wants to team up when Lightfall drops. Did I not run a few things with you years ago @BuffetSlayer?
I'd be keen to play a bit of Destiny. I work offshore on a 3 weeks on and 3 weeks off rota though. I get home on the 14th of Feb and not played for a while so needing some help if you would like to team up? OllieRendall is my PSN :)
Sure mate, my PSN ID is meths.
Feel free to add me and jump into my fireteam if you see me on. Happy to help out with anything you want to get done. :)
I ended up starting a new character.
That’s what I did in the end. The game is quite buggy not surprising since they keep chopping (vaulting) bits out of it. I enjoyed the expansions that I wanted to though I never did finished The Witch Queen. I’ll go back to it when I am ready to.
The game is especially buggy just now.
They just tired to roll out a patch to stop blue engrams dropping once you're about the soft cap and basically broke the game and had to roll it back.
That and the connection to their servers seems to be as flakey as I can ever remember it.
Hi meths, I added you on PSN. Not sure if you’ve seen my addy. Back onshore now and keen for a game if you are free sometime.
