I'm starting to do DIY on my house. The core is 1930s which was rewired at some point, and the back is a 20 year old double story extension. The last owner "renovated", and I don't trust the cabling to follow sensible runs. All walls are solid.
While tracing the hot water pipes I tore down some boxing in - and found a live capped gas pipe popping out against an internal wall.
In the older part sockets are mounted low on the skirting board such that I can't plug stiff cables into them, which might mean the cables are running behind the skirting boards, or not.
All this is making me nervous about drilling the holes I need to, in case I drill into a pipe or cable. I bought a detector from Amazon which I'm sure works fine on stud walls, but here it was useless, beeping for bumps or changes in the plaster rather than where known electrical cables ran.
Is there a gadget to help, or do I man up, point the drill and assume the best?
