I'm trying to find out if my motherboard supports Dual Role Data as described on the USB-C wikipedia entry:
https://en.wikipedia.org/wiki/USB-C#Devices
I've found from the intel website that this family of chipsets does indeed support this, in a document called "Intel 200 and Z370 Series Chipset Families PCH" datasheet. From the document:
I'm assuming that when they refer to "Port #1", this corresponds to what is labelled port #1 on the manufacturers manual (ASRock). There they label the USB 3.0 ports as : USB3_TA_1, USB3_TC_1, USB_1, USB_2. I'm trying to determine which one it is. How can I do this?
If I plug in a USB keyboard in Linux I can see the following in the logs:
Is this of any help (This was plugged in to the port USB_1)? How can I determine which port they are referring to? Does the intel document event refer to a physical plug - or do they mean 'port' in another sense?
USB Dual Role Support
The Device controller shares USB 3.0 port #1 and USB 2.0 port #1 with the host
controller, with ownership of the port being decided by the ID pin. A 1 on the ID pin
signifies that the port is to be mapped to the device controller. A 0 signifies that the
port is to be mapped to the host controller. While the port is mapped to the device
controller the host controller Rx detection must always indicate a disconnected port.
Code:
[ 1274.965729] usb 1-10: new low-speed USB device number 4 using xhci_hcd
[ 1275.140766] usb 1-10: New USB device found, idVendor=046d, idProduct=c517
[ 1275.140774] usb 1-10: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1275.140779] usb 1-10: Product: USB Receiver
[ 1275.140783] usb 1-10: Manufacturer: Logitech
[ 1275.145132] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:14.0/usb1/1-10/1-10:1.0/0003:046D:C517.0003/input/input17
[ 1275.196801] logitech 0003:046D:C517.0003: input,hidraw0: USB HID v1.10 Keyboard [Logitech USB Receiver] on usb-0000:00:14.0-10/input0
[ 1275.201473] logitech 0003:046D:C517.0004: fixing up Logitech keyboard report descriptor
[ 1275.202058] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:14.0/usb1/1-10/1-10:1.1/0003:046D:C517.0004/input/input18
[ 1275.253902] logitech 0003:046D:C517.0004: input,hiddev0,hidraw1: USB HID v1.10 Mouse [Logitech USB Receiver] on usb-0000:00:14.0-10/input1
