Device Disconnects;
28 Feb 2012
Far Far Away!
Just built a new system, and everything works fine, everything is plugged into the right port also.
There is this one problem i keep having which is starting to bug me;
I am using a USB Wifi Adapter plugged into the front USB port, I connect to the internet and it works fine, as soon as a plug another device into another usb port, the USB disconnects from the internet and then i have to reconnect.
All the right drivers are installed, so not sure whats going on?
Anyone know what might be happening?
Thanks
Definitely not the case, I bought a new one and it happened, then recenently swapped everything over to a Lian Li case, and it still happens???
