Device Restriction Software...
25 Oct 2006
Does anyone know of any software I could use to disable a device in device manager during weekdays, but enable it at weekends. Or possibly a script, if it is simple enough?
I have one PC with a webcam, and when that is used online the other PC lags on the internet and pages load slow. The ability to disable the webcam from my PC would be very useful, or a method of reducing the bandwidth it uses over MSN...
Both PCs are running Vista Home Premium :)
Thanks for any help in advance....
install pidgin, and use that instead during the week..
doesn't have webcam support, and is far better than msn :)
Yeah that's what I do atm. But I would like a solution to either do it from my PC manually with a button, or automatically disable it in device manager unless it is the weekend.
