Devices unable to connect to network. Wireless. Urgent!
5 May 2004
Northern Ireland
Hello
I am using a Belkin Pre-N router and have setup a home wireless network in my work. Unfortunately it is causing a few problems.
There is currently between 8-11 devices that are connected or needed to be connected.
While the IP list has a range of 2-100 there is a printer that has a IP address of xxx.xxx.x.200 which is a mystery to me.
The problem is that if one laptop is connected using the wireless connection and another user wishes to use another laptop on the same network, it doesn't allow additional devices to connect.
At first I thought it the IP numbering was running out but that is not the case. Any suggestions?
This is kinda urgent.
Thanks
Blackvault
DHCP is an irrelevance then - make sure they're actually connecting properly. If you're using encryption/MAC address filtering, try turning it off, and they should be listed in the router's web interface.
