Devil May Cry 4 - Help
26 Aug 2005
London
Hi,
I think it is the second mission where you have to grab those blue icons to get across the room. The ceiling has spikes so you grab at the wrong time, you fall down. How the hell do you get across without touching the ceiling and falling over?
torture chamber. Basically just watch the patterns (the blue things move and/or disappear) and wait until it isn't close to the spikes.
If its a moving one try to predict when it will form a straight line with the others
If its a diappearing one just watch the pattern it makes
When the time is right you need to use the devil bringer as quick as possible otherwise you will fall too much and end up flinging yourself into the spiked ceiling.
check out gamefaqs - there's a good guide to getting through. Worked for me when I got stuck there as well.
