Hello all,
I recently installed Devolo 1200 dlan and have a question I'm hoping someone can answer. I have the main adapter plugged into the router and mains, then two more adapters in rooms at each end of the house. The first one has pretty good figures, 250mbps dl and 80mbps ul, while the second one is showing 150 up but only around 10 down. The rate between the two however is 260/180, which made me wonder, are they able to send data from adpter 3 > adapter 2 > main adapter rather than adapter 3 > main adapter if it means better performance?
Thanks in advance for any info.
