DFI Expert and X2 AMDs Temps?
That was on a Asus A8N-SLI, I think the Expert has 4-phase power rather than 3 on the Asus so it should be a bit cooler. Certainly on a A8N32 the PWMIC was much much cooler with 8-phase power circuits.
Jokester
Have heard of some stablility probs when it exceeds 50. Not sure of whether this is true if some of you are hitting 80. Mine only gets to 45 with my 170. Runs a lot cooler on my 3700 even though this runs at higher volts (although doesnt take as much power as the dual cores)
on my ultra-d with my 170 the pwm used to hit about 75c, when it hit his kinda temp it would fail prime95 within a few mins when clocked at 2.8ghz.
Got an 80mm fan blowing over the area now and it temps dont exceed 45c and is stable
