DFI JR P45-T2RS + SG02B-F = CPU cooler?
Caporegime
6 Dec 2005
Birmingham
What CPU cooler for this board and case chaps?
Using a Q6600.
I read that a Zalman CNPS8700 wont fit on this board...
Probably the Silverstone NT06-E with a good PSU with decent airflow.
The stock cooler also fits, as well as the Zalman CNPS8000, but I found better temperatures with a standard NT06 than when using either of the two active cooling solutions.
Mini Ninja :)
Awesome little cooler, but be careful of airflow. I had my Q9550 with this in a V350 and it didn't like it...moved it all over to my eclipse and bosh, 40s under load rather than peaking at 75
- Pea0n
Mini Ninja :)
- Pea0n
A Mini Ninja isnt going to fit in the SG02 tho is it.
I've got a Zalman CNPS8700 on a DFI Lan Party JR P45-T2RS in a Lian-Li V350, I'm pleased with it.
I suggest you re-read the OP.
As for my suggestion your best bet is either a silverstone NT06E with a fan on the underside or if your feeling brave a coolermaster GeminII.
