Due in tomorrow is the new micro ATX DFI Intel X58 motherboard. Great performance with SLi and Crossfire support make this one of the most interesting X58 motherboards released. Not got many coming in so if you want one be quick.
DFI Lan Party JR X58-T3H6 Intel X58 (Socket 1366) PCI-Express DDR3 mATX Motherboard
LANParty JR X58-T3eH6 brings the best gaming experience to you! It supports both Nvidia SLI and ATI CrossFire X multi-rendering technology with 2 x16 PCI Express slots on board. The first CPU with a built-in memory controller of Intel, Core i7, running with X58 chipset of completely new configuration, will further improve performance of personal computers. X58 motherboard unveiled by LANParty this time also embodies the design philosophy of "performance first" and will bring supreme efficacy to players with top specification and material. It has 6 memory DIMMs, which support unprecedented 3-channel memory and can significantly expand the memory bandwidth; and also two PCI Express 2.0 slots, which, for the first time, simultaneously support Nvidia SLI and ATI CrossFireX and can considerably improve the 3D processing capability of the system.
- LGA 1366 socket for Intel® Core™ i7 processors
- Intel® QuickPath Interconnect (QPI) technology - point-to-point interface that connects to X58; providing a dynamically scalable interconnect for increased bandwidth, lower latency and stability
- Integrated Memory Controller (IMC) supports 3 channels of DDR3
- Intel Hyper-Threading Technology delivers 8-threaded performance
- 6-phase digital PWM provides stable voltage to the CPU
- Intel® chipset
- Northbridge: Intel® X58 Express chipset
- Southbridge: Intel® ICH10R
- System bus - 4.8GT/s to 6.4GT/s
- Six 240-pin DDR3 DIMM sockets
- DDR3 1800(O.C.)/1600/1333/1066 MHz
- Triple-channel memory architecture
- Delivers up to 43.2GB/s bandwidth
- Supports non-ECC unbuffered DIMMs
- Supports up to 24GB system memory
- Windows® 32-bit operating system is unable to accurately detect more than 4GB system memory. Therefore, if you are using this operating system, we strongly recommend that you install a less than 3GB system memory.
- 2 PCI Express (Gen 2) x16 slots - 2-way SLI or Quad CrossFireX configuration at x16/x16 transfer rate lanes
- 1 PCI Express x4 slot
- 1 PCI slot
- Award BIOS
- 8Mbit SPI flash memory
- CMOS Reloaded
- Multiple GPUs - 2 graphics cards in 2-way SLI or Quad CrossFireX configuration
- Realtek ALC889 High Definition audio CODEC
- 8-channel audio output
- 108dB Signal-to-Noise ratio (SNR) playback (DAC) quality and 104dB SNR recording (ADC) quality
- Marvell 88E8053 PCIE Gigabit LAN controller with Teaming technology
- Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
- Serial ATA with RAID
- Intel Matrix Storage technology
- Supports up to 6 SATA devices
- SATA speed up to 3Gb/s
- RAID 0, RAID 1, RAID 0+1 and RAID 5
- JMicron JMB368 PCI Express to PATA host controller
- Supports up to 2 UltraDMA 33/66/100Mbps IDE devices
- 6 layers, microATX form factor
- 24.5cm (9.64") x 24.5cm (9.64")
Just £212.74 Inc VAT
Pre-Order Now
- Intel® chipset
- 1 PCI slot
- Award BIOS
- CMOS Reloaded
Pre-Order Now
