DFI LanParty NF4 SLI-DR EXPERT?
1 Jan 2005
Stoke on Trent
hi can some 1 help me will a Ultra X-Connect 500W ATX2.0 power the DFI LanParty NF4 SLI-DR EXPERT ok?
as ive seen that the 2nd 4pin power cable as 8pin out which is odd,
thx for any help :)
oh yea i will be using a Ultra X 20pin to 24pin atx power cable
According to the manual you can use a 4 pin unless you use SLI, otherwise you must use the 8 pin eps connector. However, I'm running a 4 pin and SLI but haven't gamed with it yet, I'm still benching/setting up so can't comment 100%, using an Enermax Noisetaker 600w.
