- 12 Jan 2006
I am having problems with what memory slots to use, so figured this was the best place to ask.
I am using:
G.Skill 2GB DDR HS PC3200 (2x1GB) CAS2.5 Dual Channel Kit (F1-3200USU2-2GBHS) (MY-007-GS)
According to the manual the channels are as follows:
Channel A - DDR 1 and DDR 2
Channel B - DDR 3 and DDR 4
So in order to get the ram to run at double data rate i initially put 1 ram chip in DDR1 and the other in DDR3 (the 2 yellow slots), tried to install windows and got file copy errors, swapped them over to DDR2 and DDR4 (the orange slots) to see if it was just a faulty mobo got the same thing. I ran memtest to see if the memory was playing up and it was throwing out errors like candy on haloween after address 1024 (the second chip). So i swapped it to DDR1 and 2(1 yellow and 1 orange), ran memtest and there were 0 errors on a 4 hr test.
So figured i just had them plugged in wrong, i didnt notice it was running on single mode until it was mentioned in a another thread, so im long past the returns date afaik (bought all the kit 14th March).
Anyone able to shed light on my dilema, or is this ram intended to be run in single mode (in which case i am a bit confused why it is called dual channel :S).
Some info from CPU-Z:
Thanks in advance
I am using:
Thanks in advance
