Anyone got this combo?
Going to fit one up later on today. What's the situation with the backplate?
I understand the DFI has a plastic low profile backplate, what combination of bits do you need to fit it together? The metal H bracket if fitted underneath would touch the chips under the cpu.
Cheers.
Cheers.
