- 16 May 2004
- Cheltenham
Discovered one of the weirdest problems I've ever come across today, and wondered if anyone had seen anything vaguely similar.
Client is piloting a DFS migration, had been fine for 2 weeks but this week reported some oddities that started last weekend. One of their network drives, mapped by a login script, was reverting back to the old f&p UNC server path; this didn't seem possible given the logic in the scripts, however I think it may be a simpe case of contention and the script perhaps getting ahead of itself, so I think I've cracked that bit..
The oddity is that an E: drive has also appeared few times showing as a disconnected network drive mapping, but none of the scripts ever map anything to an E: drive; first appeared last weekend when the client was working offline (they use offline files, a lot!)..
Checked through the registry and the only evidence of an E: drive appears to have been from a locally mounted device (HKEY_LOCAL_MACHINE\SYSTEM\MountedDevices\DosDevices\E: ), probably a USB device, that's either been attached by the client or the person who made the build at some point.
So I told them this in a mail yesterday... and this morning (wasn't there unfortunately) his phantom E: drive appeared again. Someone else was with the client when he noticed and they suggested plugging in his USB stick to see what happened. Rather than mount it with a different drive label, namely F:, XP mounted it to the E: drive and when they browsed into it they found they weren't looking at the contents of the USB drive; it turns out what they were looking at, and happily browsing through, was the contents of the DFS root directory....... disconnected the stick and the E: drive vanished with it.
What the hell??? Normally if someone non-technical tells me something like this I take it with a pinch of salt, but the other guy who saw it and suggested trying the USB stick has a fairly good techie background.
Unsurprisingly I can't find anything on t'interweb about this, so I thought I'd ask you guys
