Permabanned
- 28 Dec 2009
- london
We have an issue at one site with our DR link. We had DFS running over the link for two replication groups. As a temp solution i wanted to setup dfs to another server using qnap for storage. Creating the iscsi target ok and set up the dfs. It basically ended up syncing the empty folder to the source folder and wiping all the profiles and windows documents. All the data was still at DR site but still it was a big deal and a lot hassle to fix it. Now i want to set it up again and prevent it from deleting all the source files.
Anyone have any tips on setting up to prevent it from wiping the source folders, ive used rsync before and would have thought DFS was smart enough to not sync an empty folder, but clearly MS don't put much thought in to DFS.
Ive read a fair amount on the topic and realy don't see what i did wrong, as it is pretty straight forward to add another member. Is there some special trick to prevent it from deleting all the content and ending up with two blank folders that are syncing ?
