DG834GT "switch" issues
7 Mar 2005
I've got 2 DG834GT's (originally from Sky but have DGTeam firmware on them, although not the latest).
One is connected to the net, my fileserver and hard wired to the other router which is downstairs.
I have wireless enabled on both routers with different names.
My desktop (on second router) can see and use the fileserver without any trouble at all.
My laptop, when used wirelessly, cannot see the fileserver, yet can see the desktop, no matter which router it's connected to. When plugged into netwrok cable, it can see the fileserver.
Any ideas what's going on here?
Yes. I can't remember what channels they are on at present but both are on different channels and at least 3 or 4 away from each other (i.e. channel 4 and channel 7).
From desktop:
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\Jon>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : C2D
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection 5:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Marvell Yukon 88E8056 PCI-E Gigabit Ether
net Controller
Physical Address. . . . . . . . . : 00-22-15-53-A6-C0
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IPv4 Address. . . . . . . . . . . : 192.168.200.2(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 11 March 2010 10:57:14
Lease Expires . . . . . . . . . . : 14 March 2010 10:57:14
Default Gateway . . . . . . . . . : 192.168.200.1
DHCP Server . . . . . . . . . . . : 192.168.200.1
DNS Servers . . . . . . . . . . . : 192.168.200.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection 2:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Marvell Yukon 88E8001/8003/8010 PCI Gigab
it Ethernet Controller #2
Physical Address. . . . . . . . . : 00-22-15-53-B3-CE
From Lappy coming imminently ....
From Switch wireless
Host Name . . . . . . . . . . . . : Lappy
Node Type . . . . . . . . . . . . : Peer-Peer
Wireless LAN adapter Wireless Network Connection:
Description . . . . . . . . . . . : Intel(R) PRO/Wireless 3945ABG Network Con
nection
Physical Address. . . . . . . . . : 00-19-D2-AB-EB-B1
Link-local IPv6 Address . . . . . : fe80::e040:1e47:3147:2b3e%9(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.200.4(Preferred)
Lease Obtained. . . . . . . . . . : 11 March 2010 11:05:32
Lease Expires . . . . . . . . . . : 14 March 2010 11:05:32
DHCPv6 IAID . . . . . . . . . . . : 234887390
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-12-89-FA-81-00-1B-24-22-99-4B
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : Marvell Yukon 88E8055 PCI-E Gigabit Ether
net Controller
Physical Address. . . . . . . . . : 00-1B-24-22-99-4B
Tunnel adapter Local Area Connection* 6:
Description . . . . . . . . . . . : isatap.{69F56E1B-F9ED-4EE5-8AF4-29ACC5835
E59}
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 7:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 02-00-54-55-4E-01
IPv6 Address. . . . . . . . . . . : 2001:0:5ef5:73ba:2c30:3f27:3f57:37fb(Pref
erred)
Link-local IPv6 Address . . . . . : fe80::2c30:3f27:3f57:37fb%10(Preferred)
Default Gateway . . . . . . . . . : ::
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter Local Area Connection* 9:
Description . . . . . . . . . . . : isatap.{D6AF995B-8F33-4614-B123-781084EA8
67A}
Connected via main router wireless
DNS Suffix Search List. . . . . . : mshome.net
Connection-specific DNS Suffix . : mshome.net
nection
Lease Expires . . . . . . . . . . : 14 March 2010 11:06:25
DNS Servers . . . . . . . . . . . : fe80::5db5:97dd:551e:35b8%9
192.168.200.1
Connection-specific DNS Suffix Search List :
mshome.net
net Controller
E59}
IPv6 Address. . . . . . . . . . . : 2001:0:5ef5:73bc:3455:2b19:3f57:37fb(Pref
erred)
Link-local IPv6 Address . . . . . : fe80::3455:2b19:3f57:37fb%10(Preferred)
67A}
Connected via switch wired
nection
net Controller
Link-local IPv6 Address . . . . . : fe80::bdcb:7655:5fcd:4074%8(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.200.5(Preferred)
Lease Obtained. . . . . . . . . . : 11 March 2010 11:06:55
Lease Expires . . . . . . . . . . : 14 March 2010 11:06:56
DHCPv6 IAID . . . . . . . . . . . : 201332278
E59}
67A}
C:\Users\Jon>
Attached devices from main routerwhen connected with laptop via wired
# IP Address Device Name
1 192.168.200.2 C2D
2 192.168.200.3 SERVER
3 192.168.200.5 UNKNOWN (Laptop)
4 192.168.200.100 UNKNOWN (Switch)
Attached devices from switch when connected with laptop via wired
1 192.168.200.1 UNKNOWN (Switch)
3 192.168.200.4 UNKNOWN
4 192.168.200.5 UNKNOWN (Laptop)
Any ideas chaps? This is driving me mad now!
with dhcp being off on the switch wireless i think the wireless is probably having a problem assigning an ip via the dhcp from the other router.
the router you are using as a switch was not designed to be used as a switch with wireless, why do you need two wireless active, i guess for range ?
i would disable the wireless on the second router and use it as a wired switch or you could set static ips within the same range but outside of the dhcp range. manually set the gateway to be the main router.
Assume for a moment I have no idea what you're talking about with regard to manually setting the gateway to be the main router and setting static ips (yes, I'm pretty useless when it comes to routers).
The main reason I did this was for range. Both routers have different different names, i.e routerone and routertwo.
As I use my laptop in more than one location, would it cause issues manually setting an ip?
from what i understand you said that it all works with your current setup except two of the devices can not see each othrer when they are on the second router (wireless switch)
have you tried connecting directly to the ip address \\192.168.200.3\c$ ?
The laptop cannot see the server when connected to either router wirelessly, and am now having trouble doing so when connected via a cable too. Sometimes it works, sometimes not.
I have been abroad recently and used an unsecure network. I have checked for malware since, nothing came up, and didn't put any sensitive information into web browsers or the like while doing so. Would that have caused a problem?
The server is on WHS. Plugged into router one which is also on the adsl.
I can ping it. The loss rate was zero, round trip times were 3ms.
Although after the whole lot was powered down the ip of the server has changed to 192.168.200.4
when you say "can't access it" what are you using to access it?
have you setup local shares on the WHS, did you try like i said to connect directly to ip address ?
type this into explorer's address bar \\192.168.200.4\
just like that
I've tried using the 'shared folders on server' shortcut, going through the network folder, and tried the WHS console. Neither will connect.
I tried that and got 'This web page is not found'
