DG834N v1 firmware help.
28 Nov 2004
Hi im looking for V1.01.06 - DGTeam Rev. 0743 firmware.
does any1 have it or a good 1 to use as the latest is meant to brick your router.
thx in response. ;)
DG834N_V1.01.06_DGTeam_0743
I found this one in my DL folder.Mail in trust if you want it :)
Actually i found 5 for that router up to 0850
Cant say about the above router but using the dgteam firmware usually allows you to tweak your SNR and attain either a higher synch or if you are having stabilty problems to lower it to a more stable one
