Dear ********,
DGM are now doing on site warranty though, you can come back to us if you want but it will take longer as we will just get it back and send it to them.
Regards,
PLEASE DO NOT REPLY TO THIS MESSAGE USING YOUR E-MAIL CLIENT
You can reply via WebNote:
https://www.overclockers.co.uk/webnote.php
You will then receive a reply via e-mail.
Our Address:
Overclockers UK
4 Axis, Millenium Way
High Carr business Park
Newcastle-under-lyme
ST5 7UF
Opening Hours:
Mon-Fri 8.30am-5.30pm
Sat 9am-5pm
Sales and General Enquires: [SALESNO]
Fax: [FAXNO]
Technical Support: [TECHNO]
Overclockers UK -
In reply to
I just received this reply about the faulty power supply for the DGM IPS monitor and it wrongly states that the warranty is with the manufacturer - the product description clearly states that it is a "3yr Warranty return to base with OcUK" both on the website and also on the forums from "Gibbo"
"Dear ********,
You will need to contact the manufacturer directly for all warranty claims on the DGM monitors as it states in the product description the warranty is on-site with them. Their number is 0871 250 8000
Regards,
Support Details:
Motherboard:
Motherboard Driver:
Motherboard Chipset:
Motherboard BIOS:
CPU:
Memory:
Memory Latency:
PSU:
Graphics:
Graphics Driver:
Sound Card:
Sound Driver:
Operating system:
Changes prior to problem:
