DGN2000 very poor internet connection
  • Thread starter Thread starter wnb
  • Start date Start date
wnb
wnb
27 Feb 2004
HELP!!!
My adsl line should have speeds of 1.5mbps but my pc is testing at 127k or even slower than ISDN.
I have reinstalled win7 64
Updated drivers
Replaced the cat5 cable
Tried different ports.
My wifes laptop which has vista ultimate installed using wireless internet connection runs fine as does the Ipad.
So the laptop and ipad works fine wirelessly???
I installed a wirless card for the pc but it is still as bad. I have used a cat5 cable to connect the wifes latop to the router and internet connection is perfect on her latop.
So I think I might have some sort of compatabilty issue with win7 and my router but the netgear website says their are no comapatability issues. I am stumped.
I have dragged my pc to work and its not my pc so the problem lies with some sort of compatabilty issue between my pc and my router. Look like I am in the market for new adsl modem router.
Dont use the dodgy connection to update the firmware or wireless, make sure you know the lan connection is solid as you may risk bricking the unit.
I'm now using the dg team firmware and its not helped infact the spead test is saying its slower than dial up!
I have tried everything now so its time to buy a new router, this one must goosed.
/usr/sbin/adslctl: ADSL driver and PHY status
Status: ShowtimeRetrain Reason: 0
Channel: INTR, Upstream rate = 448 Kbps, Downstream rate = 1952 Kbps
Link Power State: L0
Mode: G.DMT
Channel: Interleave
Trellis: ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 6.7 12.0
Attn(dB): 63.5 31.0
Pwr(dBm): 16.6 12.1
Max(Kbps): 2240 812
Rate (Kbps): 1952 448
G.dmt framing
K: 62(0) 15
R: 16 16
S: 2 8
D: 16 4
ADSL2 framing
MSGc: 1 1
B: 64 15
M: 2 8
T: 1 1
R: 16 16
S: 2.2461 9.0000
L: 520 128
D: 16 4
Counters
SF: 5971920 5971963
SFErr: 269 230
RS: 203045292 50760682
RSCorr: 16288171 185
RSUnCorr: 2231 0
HEC: 240 167
OCD: 6 0
LCD: 0 0
Total Cells: 467385196 0
Data Cells: 10475486 0
Drop Cells: 0
Bit Errors: 0 0
ES: 100 0
SES: 3 0
UAS: 31 0
AS: 101523
INP: 1.96 2.00
PER: 1.96 1.96
delay: 8.98 9.00
OR: 28.49 28.44
Bitswap: 0 0
Total time = 1 days 4 hours 12 min 55 sec
SF = 5971920
CRC = 269
LOS = 0
LOF = 0
ES = 100
Latest 1 day time = 4 hours 12 min 55 sec
SF = 892670
CRC = 107
LOS = 0
LOF = 0
ES = 46
Latest 15 minutes time = 12 min 55 sec
SF = 45607
CRC = 0
LOS = 0
LOF = 0
ES = 0
Previous 15 minutes time = 15 min 0 sec
SF = 52923
CRC = 0
LOS = 0
LOF = 0
ES = 0
Previous 1 day time = 24 hours 0 sec
SF = 5079250
CRC = 162
LOS = 0
LOF = 0
ES = 54
15 minutes interval [-30 min to -15 min] time = 15 min 0 sec
SF = 52923
CRC = 2
LOS = 0
LOF = 0
ES = 1
15 minutes interval [-45 min to -30 min] time = 15 min 0 sec
SF = 52982
CRC = 0
LOS = 0
LOF = 0
ES = 0
15 minutes interval [-60 min to -45 min] time = 15 min 0 sec
SF = 52923
CRC = 47
LOS = 0
LOF = 0
ES = 4
Showtime Drop Reason: 0
Last Retrain Reason: 0
