I have recently acquired a Netgear DG834 v4 router and have been experimenting with using the adslctl command over telnet to the router to reduce the SNR margin and gain higher sync speeds, with satisfactory results.
The thing is, I don't want to leave the router on 24/7 and it is a bit of a pain having to re-adjust every time so I thought that using DGTeam firmware in the router would mean my settings would be saved.
The problem is that with DGTeam firmware installed, the router appears to sync ok, says it's connected, gets dynamic IP address, gets DNS IP addresses, assigns IP addresses to PCs connected to it etc. yet no web pages will load at all. With standard Netgear firmware no problems. Does anyone have any idea what I might be doing wrong?
